05-23-2023
03:20
10:31
05-23-2023
03:20
10:31
Just to start with, I've had my Inspire for 2 years and never had any issues. I've done all the checks and re-starts so I am as sure as I can be this isn't user error.
About 10 days ago my Inspire stopped auto-recognising my walks as expertise. It still counts steps and minutes so it is tracking the activity, but not recognising it as an exercise which contributes to my exercise goals.
05-23-2023 14:37
05-23-2023 14:37
@nicki-82 , A warm welcome to the Community! Thank you for your message.
There can be various reasons why your activities were not recorded or recognized correctly.
For example, the activity is not fully recognized by your movement patterns.
You paused for more than 30 seconds during the first few minutes, so the tracker might "think" the exercise was over.
I recommend restarting your tracker and setting the start times for the activities differently. For example, set it to 10 minutes for a walk, 15 for a run, 20 for an outdoor bike ride, etc., and/or ignoring the activities you don't use.
You can find the instructions for this here.
Best Answer05-23-2023 15:16
05-23-2023 15:16
05-23-2023 15:25
05-23-2023 15:25
@nicki-82 , Thank you for getting back to me.
Just to confirm, are the walks recognized as another activity or none at all?
Best Answer05-24-2023 04:59
05-24-2023 04:59
Mine does the same thing, and restarting it has done nothing. Customer support has not helped.
05-24-2023 10:42
05-24-2023 10:42
@oldruth , Nice to see you around.
Did you tried the steps recommended on my previous post?
Are the walks recognized as another activity or none at all?
Best Answer05-24-2023 14:16
05-24-2023 14:16
05-24-2023 15:00
05-24-2023 15:00
Thanks for getting back to us @nicki-82.
Could you please confirm that you have tried setting up your Inspire as a replacement device with the instructions of: How do I set up a replacement device or add another device to my account?
Best Answer05-24-2023 18:58
05-24-2023 18:58
Yes, I've rebooted it and it didn't correct the problem. I used the charging thingy. My walks are just steps, even if I'm walking at an aerobic pace. It doesn't recognize walks as exercise. It did for the first 6 days, and then it stopped.
05-25-2023 10:01
05-25-2023 10:01
Thanks for getting back to us and for describing what happens with your walks @oldruth.
I understand how frustrating this could be and would confirm to also set up your Inspire as a replacement device with the instructions from my previous post.
Best Answer05-25-2023 11:28
05-25-2023 11:28
05-25-2023 11:32 - edited 05-25-2023 13:04
Thanks for getting back to us and for the clarification @oldruth.
Please just follow the set up instructions with your current device.
Best Answer05-25-2023 12:18
05-25-2023 12:18
I have. I read the whole manual. It isn't behaving the way the manual said it would.
Best Answer05-30-2023 03:33
05-30-2023 03:33
05-31-2023 13:33
05-31-2023 13:33
i am having the same issue! stopped recording exercise on 5/17. Records the steps correctly. It is frustrating that customer support is not offring solutions and repeating the same advice!!!!!!!!
05-31-2023 14:02
05-31-2023 14:02
Yes, I've given up on it. It also says that I'm in "deep sleep" when I'm reading in bed, so my sleep totals are off every day from 30 to 120 minutes, depending on how bad my insomnia is. I've got to send it back but I'm busy right now getting ready to go away for the summer.
Best Answer06-02-2023 05:29
06-02-2023 05:29
I'm having the same issue, mine stopped recording my walks the same day, the problem isn't with us, it must be a fitbit problem.
