08-16-2020 04:48
08-16-2020 04:48
Any time I've traveled out of state, my Inspire always changed time zones automatically along with my cellphone. Now that I've moved from Arizona to Indiana my cellphone clock is on Indiana's time but the Inspire is on Arizona's time, a 3 hour difference. I found the time zone & location automatic setting had been turned off, so I turned them on. I turned my cell off and back on, but the Inspire's time still shows AZ time, 3 hrs earlier than IN. There doesn't seem to be a setting for EST- Indiana. It only has GMT and all the rest of the world. Any suggestions other than buying a new Inspire?
08-18-2020
13:02
09:58
08-18-2020
13:02
09:58
@SunsetRunner It's nice to have you on board!
Let me help you with updating the time on your Inspire and thank you for troubleshooting this issue. There is no need to buy a new device. I would recommend you restart your tracker by following these instructions. After this try changing the timezone, select a different one, save and sync then select the correct one, save and sync again. I could see that the app does have an Indiana (East) option, if this isn't the correct one for you then select one that is the same as your current timezone (select a different location with the same timezone).
Let me know how it goes.
Best Answer08-18-2020 19:30
08-18-2020 19:30
Thanks so much. I appreciate your help. Inspire clock did finally sync with my cellphone.
11:37
09:58
08-25-2020
11:37
09:58
@SunsetRunner thank you for the update.
Really happy to hear that your tracker is working fine now and thank you for letting me know that the suggestions helped you as this may help other members in the same situation.
Happy stepping and stay safe.
