09-07-2021
11:03
11:36
BraulioFitbit
09-07-2021
11:03
11:36
BraulioFitbit
Hi my inspire won't sync, won't registar sleep and alarm has stopped working.
09-07-2021
13:05
05:31
09-07-2021
13:05
05:31
@NH42 I hope you are doing fine.
I suggest you try the following:
This should help syncing and once it syncs we should see if the sleep shows there. The restart should help with the alarms.
Hope this helps.
04:11
05:31
09-09-2021
04:11
05:31
@NH42 hopefully this will get your tracker syncing again. Remember that your tracker will save detailed data for a week (7 days) and the daily totals for 23 additional days.
I'll be around.
