I usually run on the same route. Timing my pace by my downloaded playlist. Tired of the same playlist.
Want my Inspire HR to time the intervals instead. Want to set intervals at certain points/times eg. 3.52 mins.
Is it possible to set voice or buzz notifications on the inspire hr to pace my run by going off at certain times on a run ?
@dbee01 Thanks for stopping by!
Let me help you with setting up intervals for your runs. You can't setup the intervals the way you described (at 3:51 minutes) you can select either distance or time on the Fitbit app but for example when using time you can select between 2, 3, 4, 5, 10, 15 mins etc. You will find this feature by tapping the exercise tile on the Fitbit app then then stopwatch where you will see the options to set running cues. If you wish to have more options when using this option then you can share your idea in our Feature Suggestions board. Search for the idea first to see if one already exists so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Let me know how it goes.
