08-06-2019
10:49
13:55
YojanaFitbit
08-06-2019
10:49
13:55
YojanaFitbit
Big question is "will Fitbit Inspire be supported on the Mac?"
08-07-2019 14:03
08-07-2019 14:03
How are you doing my friend @tommylovell? Welcome!
You have a great question there. Actually, if you don’t have a compatible phone or tablet, you can sync your Fitbit device on your computer (Mac or Windows 8.1 computer) using Fitbit Connect. You can find this information here: How do I set up my Fitbit device? You can set up your Inspire with any of this options: Which phones and tablets can I use with my Fitbit watch or tracker?
Let me know if you have questions about this.
Best Answer08-07-2019 18:39
08-07-2019 18:39
Best Answer12-27-2019 09:49
12-27-2019 09:49
Did you ever get this resolved? I gave my mother an Inspire for Christmas & it has just turned into a disappointing gift. She cannot get her computer Bluetooth to "see" her tracker either. I hope you can help?
12-27-2019 15:48
12-27-2019 15:48
12-28-2019 06:11 - edited 12-28-2019 07:24
I had the same problem on a Macbook Pro and imac but it worked perfectly with my partners laptop.
Something I noticed with Apple was how it doesn't show the entire screen when selecting which Fitbit tracker to set up and I believe there is an option to click a link at the bottom of the box to sync with a Fitbit Inspire.
I'm struggling to upload a screenshot but basically the box that appears during setup shows 2 rows of 5 devices and a Fitbit One at the bottom half cut off with no way to resize the box or scroll to show the missing links.
I hope this makes sense.
Edit: I was told by Fitbit support that Macs aren't supported. In that case why does it offer the download to Fitbit Connect and not warn us at that point that Apple computers are not supported.
12-29-2019 05:47
12-29-2019 05:47
Having the same problem, I find it troubling that nowhere does it state clearly that Fitbit Connect is not supported with Inspire. Disappointing, hopefully I'll be able to return the device. 😞
05-28-2020 09:10
05-28-2020 09:10
AccodingInspire User Manual (which you have to look for and is not readily available on site) the Inspire Fitbit is NOT supported by Mac. You cannot set up your device via Mac and you cannot use Mac to sync.
If you want to use it at all you will need a mobile device or a Windows 10 computer in order to sync and properly track
