12-11-2021
11:48
18:36
GraceGFitbit
12-11-2021
11:48
18:36
GraceGFitbit
The notifications menu on the fitbit app on my android phone keeps diappearing so I can't set certain apps or phone calls, etc, to notify my inspire. The menu reappears if I uninstall and reinstall the app and enable all the permissions, but a few hours later it disappears again. I really need to get my email notifications on my inspire. Help! Thanks.
Hi @BrittLew, thanks for posting your inquiry here and for the time you've taken to look for a solution.
The Fitbit app needs to run in the background in order to enable features like notifications. Did you check ? For more information, see Why does the Fitbit app need to run in the background on my Android phone?
You can also try the tips in this help article : What are some tips for using the Fitbit app on my Android phone?
See you around.
