10-29-2020
08:29
19:20
RicardoFitbit
10-29-2020
08:29
19:20
RicardoFitbit
Serious delay of all notifications from whatsapps or call after I upgraded the firmware. Sometimes it would be few hours delay. Anyone has similar problem? How to fix it? I tried to remove and add as new device again in fitbit apps, but the problem can't solved.
19:19
06:27
10-30-2020
19:19
06:27
Hi @Wingluk, welcome to ther Community Forums!
I appreciate the details that were shared in your post and for trying some troubleshooting steps before posting. To better assist you with this, can you please let me know which mobile device you're currently using? Also, when was the first time you experienced this? If you haven't already done so, I recommend you to check: How do I get notifications from my phone on my Fitbit device? to see that all the necessary requirements to receive notifications on your Fitbit are correctly configured and to try some troubleshooting steps.
Looking forward to your reply.
Best AnswerMy mobile device is Samsung Galaxy S10 with Android version of 10. The first time I encountered this problem should be about 2 weeks before. I haven't changed any settings in my phone or fitbit apps at all. And it worked when I tested by "Call Notification", any hints to solve this problem?
Best AnswerI've been having the same issue. Very delayed notifications for all apps- calendar, WhatsApp and calls. Did a reboot on both devices and removed and the added the tracker with no luck. Using a Pixel 4a.
