07-25-2019
17:05
13:36
YojanaFitbit
07-25-2019
17:05
13:36
YojanaFitbit
Every time I charge Fitbit, I notice after, I won’t receive notifications on it until I do a reset on the Fitbit. It’s extremely frustrating and annoying! What can be done?
Best Answer07-26-2019 13:34 - edited 01-01-2020 11:07
Hi @Amber87777 nice to see you here. Thanks for sharing the notifications issues with your Inspire HR. I'll be glad to give you a hand with that.
Notifications skip or stop occasionally for several reasons, I'd like to check with you some steps to make them work again with your phone.
Requirements for a successful synchronization:
If the syncing issue remains, I would recommend following the steps below:
This should solve those issues that you're having, please keep me posted on the resolution! ![]()
Best Answer02-22-2020 03:19
02-22-2020 03:19
I have the same issue and doing all of these things has never permanently solved the issue. Every time I charge my Inspire I go into the notifications settings, turn them all off, sync the Fitbit, then turn them all on again and resume. Then they all work again. It’s annoying to have to do every time though.
Best Answer03-17-2020 13:47
03-17-2020 13:47
I have the same issue! It’s incredibly annoying! Although mine will work fine one minute and then all of a sudden stop and I have to reset it with the charger and sync it again. Fitbit needs to get it together!!
Best Answer08-02-2020 12:11
08-02-2020 12:11
Anyone had any luck resolving this issue I have Huwaei P20 Pro...and my notifications work for a while and then suddenly stops working...i have to clear data & cache...re login to app and then turn on notifications again...its getting super annoying and putting me off using my fitbit as I'm not sure I can rely on it if my notifications suddenly stop working.
