01-01-2022
15:40
23:01
01-01-2022
15:40
23:01
My husband isn't getting notifications for texts or calls. His settings are all set up the same as mine.
01-01-2022 15:49
01-01-2022 15:49
The issue has been resolved
Best Answer01-02-2022 09:21
01-02-2022 09:21
What did you do please. I have same issue. All settings are enabled for notifications. I can't even get the movement reminder. Thank you
01-02-2022 10:02
01-02-2022 10:02
Make sure vibration is turned on in settings and DND & Sleep are turned off on Fitbit
Best Answer01-02-2022 13:09
01-02-2022 13:09
Thanks
