05-06-2020 03:14
05-06-2020 03:14
Hi I really need some help! I have not used my Fitbit in months, and now the screen is black and it is not connected to any device. It vibrates when I touch it sometimes, and a smiley face has come up as well but other than that it is not responding. I do not have the heart to throw it away and really need some help. I can’t even return because my warranty is over. HELP!
03:45
05:59
05-06-2020
03:45
05:59
Hi, @Reaiah , the best thing you can do is to give it a couple of hours charge. even if it does not seem to be charging, and then try the restart:
You may need to repeat the restart process several times, and you may need to hold the button for considerably longer that 5 seconds, but with luck it will spring back to life again.
Let us know how it goes. Welcome to the forums!
Best Answer05-06-2020 04:27
05-06-2020 04:27
Hi, thanks for the advice. I tried this and the smiley face showed up, but after that the screen went black again. And now it just vibrates on its own every 5-10 seconds
Best Answer05-06-2020 04:48
05-06-2020 04:48
Hi, @Reaiah , I would suggest trying the restart procedure a couple of times more, and if that doesn’t work unplug it and let the batter die completely and then start all over again with 2 hours charge and then the restart. As it is out of warranty there is not a lot more than can be done. But it might just work.
