08-02-2022 12:39
08-02-2022 12:39
Hi Folks.
The strap holder of my Fitbit Inspire HR broke. I glued it in with gorilla glue, however in the heat, it just keeps falling off. Everything works fine, except no straps. Is there a way to fix it? If not, where can I recycle it, coz I don't want to just trash it.
Thanks
Best Answer08-03-2022 04:18
08-03-2022 04:18
Hello @Annabeck and welcome to the Community. You're correct that you shouldn't put your Fitbit in the regular trash. A lithium ion battery shouldn't go in the trash. Please check with your local recycling rules. My county has a drop off for hazardous items. In the US, some hardware stores like Home Depot have battery drop off bins, too.
Laurie | Maryland
