03-25-2019 05:36
03-25-2019 05:36
How do I launch the relax app in iOS ? Is it incorporated in the Fitbit app ?
How can have access to it ?
thanks a lot
Best Answer03-25-2019 06:18
03-25-2019 06:18
It should just be a case of swiping down when showing the clock to see the installed apps and then tap on relax when you find it. I think that, by default, it's the fourth in the list.
03-25-2019 05:57
03-25-2019 05:57
The Relax app runs on certain fitbits rather than in the fitbit app on the phone.
It is there on the Inspire HR but not the standard Inspire. Which do you have? There's a help file for it at https://help.fitbit.com/articles/en_US/Help_article/2077/
Best Answer03-25-2019 06:15
03-25-2019 06:15
Hello Steve,
thanks a lot for your reply.
i have the inspire hr but I cannot find a way to launch it 😞
03-25-2019 06:18
03-25-2019 08:26
03-25-2019 08:26
nope, not appearing when I swipe down even though the relax app appears as “downloaded” in my apps list
03-25-2019 11:10
03-25-2019 11:13
03-25-2019 11:13
I don't know what to suggest. Hopefully someone else will be able to solve the mystery
Best Answer03-25-2019 11:23
03-25-2019 11:23
I found it !!!!!!
no idea how 😂
thanks a lot !!!
Best Answer03-25-2019 11:30
03-25-2019 11:30
Now I understand I was swiping up instead of swiping down.
thank you Steve for your help !
have a nice evening:)
03-25-2019 11:32
03-25-2019 11:32
I'm glad you got it sorted.
Best Answer03-25-2019 12:43
03-25-2019 12:43
I found it now also by swiping down but I think it was that I totally shut off and restarted my phone before trying the down swipe again
Thanks!
Best Answer06-30-2019 14:48
06-30-2019 14:48
I have the same problem with my inspire HR. The relax app does not appear on my devise but the app says it’s installed.
