12-24-2019 10:18
12-24-2019 10:18
Hello!
I have a question about exercise shortcuts. I saw a video where it was possible to add/remove exercise shortcuts, but with my Fitbit Inspire HR it's not possible. Am I doing something wrong or is this a thing you cannot change?
What is more, is it possible to change the things my clock shows? Is it possible to delete maybe the weight, distance etc on the Fitbit so that it doesn't show these features on the clock?
Best Answer12-24-2019 10:46 - edited 12-24-2019 20:59
Exercise Shortcuts
Computer Dashboard go into settings and look for exercise shortcuts. Uncheck the ones you dont want and check the ones you do. You can also move them around. Same for Phone find exercise shorts cuts and do the same.
It can not be done form the device itself
Wendy | CA | Moto G6 Android
