08-13-2024 07:04
08-13-2024 07:04
Being totally bummed they got rid of the web so spent too much time yesterday trying to switch from Fitbit to Google, since Fitbit app won't be supported in 2025. Nothing worked, even though I had help from tech. Finally I decided to uninstall the Fitbit app, waited 10 minutes and install it from google play store. That worked, as the option to switch to google was there. The app is quite a bit different. I've been trying to find when in that app you set an alarm and can't find it. Additionally, I can't find anything in the app that tells you what unit you have. The old Fitbit app had the type of unit in your profile area. Help, please and thanks.
08-13-2024 17:56
08-13-2024 17:56
@sandycrochet your can find instructions for setting an alarm here.
To find which Fitbit model you have, tap on the battery/device icon in the upper left of the Fitbit app home screen. The next screen will show what Fitbit you have.
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
08-13-2024 07:17
08-13-2024 07:17
After much heartache yesterday trying to switch to Google Fitbit, I uninstalled my current Fitbit app, waited 10 minutes and installed from google play store. There finally I was able to get switch, as the prompt was there. But, now I can't find:
I am an android user
08-13-2024 17:56
08-13-2024 17:56
08-14-2024 05:22
08-14-2024 05:22
Thanks so much, that's very helpful. Clicking on the battery also helped me find where to set an alarm. Appreciate your help.
