06-26-2019 03:26
06-26-2019 03:26
I ave researched this and cannot find a solution. I have done the soft reset several times and checked setting on both my phone and my Fitbit Inspire. It does not record my sleep at all and the icon on the device is not active.
06-26-2019 08:20
06-26-2019 08:20
I have the same issue. The Inspire updates my sleep on my dashboard, but the display on the device itself does NOT update. I've managed to get it to light up with the stats once or twice but I'm not always successful. So far, I haven't found a solution and C.S. has not been helpful.
06-26-2019 13:12
06-26-2019 13:12
Mine actually does not log sleep at all unless I manually tell it that I am ready to go to sleep and that I am awake the next day
06-26-2019 20:30
06-26-2019 20:30
E
Why. Is. My sleep. Icon grayed out
06-27-2019 04:31
06-27-2019 04:31
I finally resolved my own issue. I did a soft reset on my Fitbit and also found that instead of showing on my wrist it was on Clip. Now the icon is active and it tracked my sleep last night
Best Answer06-28-2019 07:32
06-28-2019 07:32
I had already checked that. I'm still having an issue.
08-16-2019 21:57
08-16-2019 21:57
How did you correct the problem? I am having the same problem and can’t figure it out
08-17-2019 04:31
08-17-2019 04:31
I found out that my tracker was set to clip instead of wrist and once I changed that setting, it started working correctly.
Best Answer08-17-2019 04:32
08-17-2019 04:32
Also try to do the soft reset on your tracker
Best Answer08-31-2019 12:24
08-31-2019 12:24
I went to my fitbit settings and turned off and on the phone GPS and it worked.
Best Answer12-10-2019 23:18
12-10-2019 23:18
I fixed this issue myself. My bluetooth was turned off on my phone. Once I turned it back on everything loaded it my phone and watch both.
Best Answer12-26-2019 03:54
12-26-2019 03:54
What the sleep icon is for is so that way when you toss and turn, you don't wake up with a bright clock shining at you. Instead, the moon is dimmer than the normal screen, so when you toss around, it wont blare a bright light at you, instead you probably won't notice it.
12-30-2019 19:14
12-30-2019 19:14
I'm having the exact same issue. however, my fitbit is set on wrist and both my location and Bluetooth have been on ever since I received the fitbit. I've reseted it multiple times, dispaired the fitbit from the app as well as continously synced it- at this point I've kind of given up and now I just manually entered sleep tracker into the app instead. 😂
Best Answer03-12-2020 10:16
03-12-2020 10:16
Thanks a lot but how did you do a Fitbit soft reset, please? Woke up this morning to the horror that my Fitbit hadn’t recorded my sleep at all last night and I kind of need to know this things. My icon is grayed out as well , please help 😞 :(!
03-12-2020 10:16
What does it mean by it was on clip?
Best Answer05-17-2020 18:29
05-17-2020 18:29
how do you do a soft reset?
Best Answer05-17-2020 18:36
05-17-2020 18:36
How do you change it from clip to wrist
Best Answer06-07-2020 10:53
06-07-2020 10:53
Where to you find it said it was on clip? I don't see that anywhere on my fitbit app.
