09-23-2019 02:00
09-23-2019 02:00
Hi there,
I used the sleep tracking 3 times so far. First 2 times I clicked the "begin sleep" button but apparently, that doesn't record the quality of sleep but just duration. So after reading a post which suggested just go to sleep and it will track it, I realised it did not. I had to manually put it in but again no actually quality data.
How do I get my tracker to record the quality of sleep also?
14:14
06:08
09-24-2019
14:14
06:08
Hi @Ramanreb nice to see you around.
I'm glad to see that you're using your Inspire HR to track your sleep information. Thanks for visiting the Fitbit Forums to look for information about how to track sleep. You're right, you don't need to click the option "Begin Sleep". Instead, please check this useful post with important information about sleep.
If you need more information you can also check this article: How do I track my sleep with my Fitbit device?
Let me know if you need more information.
Best Answer09-24-2019 17:05
09-24-2019 17:05
Sleep tracker is not working at all.
Days exercised not working at all.
Time to get moving not working. at all.
Steps is working on the fitbit but does not sync with app on phone, says 0 steps.
