08-03-2020 17:21
08-03-2020 17:21
I have had my Inspire for 3 months. The last 2 nights it has not tracked my sleep. No settings have been changed. What do i do? Thanks!
08-04-2020 02:59
08-04-2020 02:59
Hi, @Wymrlover , usually when your Fitbit is not behaving as expected the first troubleshooting step is to give it a restart:
It also is important to check for any update in the Fitbit app.
For sleep tracking it is also helps to make sure your Fitbit is well charged - preferably at 30% or more.
Sometimes the Fitbit cannot consistently detect your heartrate, often because your wrist is in a flexed position while you are sleeping, and then sleep tracking may fail. Obviously you cannot help this! But hopefully with a restart, and checking for app update, normal service will be resumed tonight.
Good luck and let us know how it goes. Welcome to the forums!
Best Answer08-04-2020 07:04
08-04-2020 07:04
I have been using the Inspire (not HR) since the middle of July, moved over from the One. It occasionally monitored sleep at first, but it tended to think whenever I was sitting at my computer the clip did not pick up movement. Now it picks up nothing as far as sleep goes, I do manually add it in the log when I get up. And occasionally I add a nap in.
Best Answer08-04-2020 10:06
08-04-2020 10:06
Best Answer08-04-2020 10:08
08-04-2020 10:08
Best Answer08-04-2020 10:12
08-04-2020 10:12
Hi, @Wymrlover , these are the instructions for resetting:
This will not recover sleep that was not tracked in the past - unfortunately that is not possible - but should help fix the problem moving forward. As mentioned above, ideally keep your Fitbit charged to 30% or more (charging little and often is ideal and will also preserve your battery life long term). Also make sure the Fitbit is snug on your wrist but not overly tight.
Best Answer08-04-2020 10:14
08-04-2020 10:14
