07-19-2019 15:15
07-19-2019 15:15
Received replacement Inspire HR and tried to sync with the Fitbit Connect.app but it does not sync only shows low battery from old unit
Best Answer07-20-2019 05:50
07-20-2019 05:50
Try adding the replacement as a new device and when you say it is an Inspire HR it should ask if you want to replace the old device with the new one.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
07:10
09:30
07-20-2019
07:10
09:30
@slaga, a warm welcome to our Community!
Let me help you with your replacement Inspire HR. Your account won't simply sync with it as a link needs to be created between the new device and your account. As @wtksk8r you will need to set it up as a new device on your account. Please follow these instructions to do so.
Let me know how it goes.
Best Answer07-20-2019 09:44
07-20-2019 09:44
08:52
09:29
07-23-2019
08:52
09:29
@slaga thank you for the update. Sorry for the late reply.
Happy to hear that your tracker is working now and thank you letting us know that everything worked well in the end.
I'll be around.
