I just upgraded from an Alta to an Inspire HR and the syncing is annoying me
i have two iPads and an iPhone and I could sync my Alta to all of them. The Inspire seems to want to connect to a SINGLE device and not let go. There’s not even a Bluetooth disconnect option!
Anyone found a way around this?
Thanks
Phil G
Best AnswerIt often helps to temporarily turn off bluetooth on all of the sync devices (iPad or iPhone) but the one you want. Once you sync with one, the others should still get the data from the main fitbit database.
