02-07-2020 11:10
02-07-2020 11:10
I need tech help - the screen does not respond to tapping
Best Answer02-07-2020 11:20
02-07-2020 11:20
Here, also ... my screen is black.
otherwise, it seems to work, communicating with the app on my phone.
Best Answer02-07-2020 12:22
02-07-2020 12:22
Me too, and I just got it for Christmas. This is the second FitBit I've that this happened to. The first was a Versa, which the company would not replace. Worst warranty EVER!!!! They don't stand behind their products.
Best Answer02-07-2020 13:10 - edited 02-07-2020 13:11
I called FitBit Customer Service at 877-623-4997 and spoke with a very nice person who walked me through “Resetting my Inspire HR”. I just put the band on the charger. Hold the button for 5 seconds. Release and a smiley-face displays on the screen. I was back in business. Hope this helps someone. Best regards/
02-07-2020 15:18
02-07-2020 15:18
Thank you for your post, it seems to have solved the problem. 🤠 akalopaka
02-07-2020 19:04
02-07-2020 19:04
It worked. Thank you
02-07-2020 19:32
02-07-2020 19:32
Thank you, this worked!
02-08-2020 05:22
02-08-2020 05:22
It worked for me also - but I had to hold the button a little longer - but it worked!!
Best Answer02-08-2020 11:48
02-08-2020 11:48
Does NOT work for me. The fit bit is not seen by any IOS phones or devices, is not broadcasting any blue tooth signal. Mine went blank when updating for the first time. I let it update for almost 2hrs and the watch just seemed to have died during the update. No response to tapping, 5 sec reset, etc.
Best Answer02-08-2020 13:52
02-08-2020 13:52
Just had mine as a gift. Says it is fully charged in app but there is just a horizontal pink line across the screen and it doesn't respond at all.
Best Answer02-08-2020 14:52
02-08-2020 14:52
My Inspire HR did the same, I read your post , tried it and it worked. Thanks for your post.
