07-08-2019 01:00 - edited 07-08-2019 01:32
I'm really struggling here. Managed to get the bar thing out but have been trying for ages to put it in the new band and now the little pin thing has come out and the body of the bar is stuck in the band.
It all seems a fiddly faff, would I be better off just buying loads of those bars to put in my different bands (assuming I can get them in) as I do change bands most day?
Update: Managed to remove bar with pliers, couldn't get the pin back in but managed to get back into my original strap.
Going to see if I can order more of those bars as that pin came out really easily so I will probably need some back ups. Still not sure how to change bands.
06:52
07:48
07-09-2019
06:52
07:48
@MehPerson1, it's great to see that you've visited the Fitbit Community!
Let me help you changing your Inspire HR bands. As you mentioned one suggestion is using pliers but also other members have used tweezers to do this and have been successful about it. You can check a guide on how to change bands here.
Let me know how it goes.
Best Answer07-09-2019 10:25
07-09-2019 10:25
I bought a band on Amazon and it came with extra pins. Maybe you can order those there? I can see how they would be extremely easy to lose because they are SO tiny!
