I can't get my Inspire to setup with my app, I have a flex 2 already on my app. Do I have to delete that to setup my new Inspire?
03:40
05:58
05-06-2020
03:40
05:58
Hi, @KCSTAR , you can have both the Flex 2 and Inspire on the same account, so that won’t be the issue. However, it might be a good idea to move the Flex 2 out of range while you do the set up, just in case the Bluetooth signals are interfering with each other. Also please move any other devices with Bluetooth out of range or else turn their Bluetooth off, leaving only your new Fitbit and your phone for the set up in range.
Then I would suggest giving your Inspire a restart before trying the set up again. Instructions for restart here:
I hope this helps. Welcome to the forums!
Best Answer@KCSTAR in that case I would recommend deleting the app completely and then redownloading it. As long as you use the same username and password you will not lose any data.
