03-07-2019
12:01
14:14
MattFitbit
03-07-2019
12:01
14:14
MattFitbit
I need help on choosing a new fitbit Versa vs InspireHR
Moderator edit: edited title for clarity
Best Answer03-07-2019 12:04 - edited 03-07-2019 12:05
Welcome to the forums!
It really depends on what you want on your device. You can compare then here:
The size is a big difference so it that matters I would go for the smaller one Inspire
Hope to see you around the forums! Join in on the discussions forums!
Wendy | CA | Moto G6 Android
03-07-2019 14:23
03-07-2019 14:23
@somone2012 Like Wendy said, I would compare them to see what best fits your needs. I love my Inspire HR. It's very lightweight and I barely notice it's on. The screen is small, though, so if you like the bigger display of the Versa, that might be a better choice.
The Inspire HR fits great on my small wrists and looks very delicate and feminine.
Best of luck deciding!
03-10-2019 15:17
03-10-2019 15:17
the versa is also more of a smartwatch than tracker so there is a price point difference. It really is based on what you want to do with your tracker.. do you want to count steps or steps and floors, do you care about HR, do want to have apps, do you need a larger display.. the list is long. Good luck choosing, I hope in the end it is exactly what you are hoping for.
Elena | Pennsylvania
