06-12-2019 14:14
06-12-2019 14:14
Hello!
I have lost roughly two pounds since I got the inspire hr a week ago, but when I logged my new weight it doesn’t say I had lost any weight on the dashboard. Does it take a while for it to change? I put it in this morning and it still says “- - lbs”
Best Answer06-12-2019 21:44
06-12-2019 21:44
@AlexaLhello Congrats on the 2 lbs! The -2 should show instantly. Did you log a new weight from your dashboard OR did you go into your account settings and change your weight in your profile? If the latter, it won’t show it as a change.
Best Answer06-24-2019 09:18
06-24-2019 09:18
I figured it out. For some reason it changed my start date, so all I had to do was edit that manually. Thanks!
