08-11-2019 06:53
08-11-2019 06:53
My inspire hr is stuck on the time face and will not swipe up or down. I can’t see any of my details, steps etc. How do I fix it? Also syncing is sporadic.
Best Answer08-11-2019 07:27
08-11-2019 07:27
Me too. It's frustrating. I've put it onto charge & tried reset but hasn't reset
Best Answer08-11-2019 07:58
08-11-2019 07:58
I can’t swipe either! Very frustrating Any suggestion?
Best Answer08-11-2019 08:47
08-11-2019 08:47
I decided to try completely removing the Inspire HR and then adding it back. That has resolved my issue. It’s like a reboot I guess! Good luck out there!
Best Answer08-11-2019 08:49
08-11-2019 08:49
Best Answer08-11-2019 09:06
08-11-2019 09:06
Thanks, have put mine on to charge to see if sorts it!!
Best Answer01-12-2020 11:53
01-12-2020 11:53
Did your issue get resolved??
Mine is new, and can't swipe at all 😔
Maybe I should return
Best Answer01-12-2020 13:52
01-12-2020 13:52
Mine has the same problem, I just bought it yesterday!
