08-19-2019 00:56
08-19-2019 00:56
how do I update the time on my watch face? I have an Inspire HR
Best Answer08-19-2019 01:30
08-19-2019 01:30
You can't manually set the time but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the timezone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
Best Answer08-20-2019 13:24
08-20-2019 13:24
Hi - Thank you for that info. However my Fitbit is not syncing. I have recently bought this new one and it won't sync. Any suggestions?
Best Answer08-20-2019 23:24
08-20-2019 23:24
If it is a new fitbit and has never synced then it's worth checking that your phone is supported by fitbit at www.fitbit.com/devices
If it has worked ok but has now stopped then the usual things to try are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
