08-04-2019 20:53
08-04-2019 20:53
I had a fitbit ONE, I now purchased an Inspire HR. Can I use same email address to get notifications? No longer use fitbit ONE.
08-04-2019 21:04
08-04-2019 21:04
Hi @SunsetRunner
Sure you can. Set up as a new device on an existing account and your history will be there for you. Glad you're with us.
08-04-2019 21:05
08-04-2019 21:05
Hi @SunsetRunner Yes you can. If the One is still on your fit it account either remove it or turn notifications to the One off. Then it should send notifications you have set up to your Inspire
Helen | Western Australia
08-04-2019 21:12
08-04-2019 21:12
08-04-2019 21:28
08-04-2019 21:28
I am not sure what you are asking. Can you clarify? Just a typo I think but I cant work it out lol
08-04-2019 21:31
08-04-2019 21:31
08-04-2019 21:32
08-04-2019 21:32
I can not find the ONE on my account.,.to remove it. I purchased an InspireHR.
08-04-2019 21:33
08-04-2019 21:33
Do email notifications appear on InspireHR?
08-04-2019 22:12
08-04-2019 22:12
You do not need to remove the one from the account.
Please be more specific so we can help you
Wendy | CA | Moto G6 Android
08-04-2019 22:14
08-04-2019 22:14
@SunsetRunner wrote:
How do I do d my devices? I did use an alternate email..but it is not the
email I check regularly
Sounds like you set up a new account, Is this the case?
You are very unclear and its hard to help
08-04-2019 23:00
08-04-2019 23:00
Hi again. If you cant see the One on your account then it is probably not there. I am not sure, as @WendyB says, if you have used your original account that you had the One set up on or opened a new account using a different email address.
08-05-2019 04:05
08-05-2019 04:05
Message I receive says my email is already used. So I need to choose a different email address. Not sure why....... So I thought it was because I had a different Fitbit.
08-05-2019 04:08
08-05-2019 04:08
Yes I set up a new account, (using an alternate email that I don't check often). Would MUCH rather use the original email. How do I switch my preferred email?
08-05-2019 04:27
08-05-2019 04:27
08-05-2019 04:28
08-05-2019 04:28
08-05-2019 04:29
08-05-2019 04:29
Yes that spunds as if you were trying to set up a new account usingnthe old email address. If you remember your password then just log into the old account. If you forget the password you can request a password change. Then once you get into the old account you can set your Inspire up again in that account. Does that make sense?
08-05-2019 04:33
08-05-2019 04:33
08-05-2019 05:00
08-05-2019 05:00
As far as I am aware you only get that message when you try to create a new account with the old email address. If you are selecting Log In (not create an account) and get that message, you will need to contact Support about it (link in my signature) as there is nothing anyone on the forums can do.
08-05-2019 05:03
08-05-2019 05:03
08-05-2019 05:22
08-05-2019 05:22
No idea what is going on, but if it is working - great! 🤣🤣
