08-09-2019 12:50
08-09-2019 12:50
I just got the inspire HR. Can I pair it with the zip?
Best Answer08-10-2019 00:00
08-10-2019 00:00
Are you asking if you can have both the Inspire and the Zip connected to your account at the same time?
If so, then: Yes. There are limitations on what combinations are supported but your combination should be fine. There's more information on this at https://help.fitbit.com/articles/en_US/Help_article/1715/
To add a second device to your account, go into the account section of the app and select "set up a device". All your data, settings, badges etc will be retained.
