05-01-2020 22:36
05-01-2020 22:36
I need a 24h clock, and today my VersaLite reverted to a 12h clock. There is NO OPTION I set advanced settings to change this. Please help!!
Best Answer05-02-2020 00:31
05-02-2020 00:31
Did you change clock face? Some clocks override the system setting.
If not then you can find the settings to change it via the web interface at https://www.fitbit.com/user/profile/edit
There you'll find the "clock display time" setting. Once changed and saved, the next time you sync yout fitbit will be updated.
05-02-2020 00:31
Best Answer05-02-2020 17:38
05-02-2020 17:38
Thank you!!
Best Answer05-05-2021 05:36
05-05-2021 05:36
Worked for my Versa 3.
