12-08-2018
13:09
18:13
EdsonFitbit
12-08-2018
13:09
18:13
EdsonFitbit
Hi, I received from Fitbit Community this email: "Great job! sethington marked your answer to a question as an accepted solution! ". Although this is of course great for me, but there are two problems:
1. I cannot see in my answer to the post of sethington that it's accepted as a solution
2. This is sethington's post regarding this issue: "
This forum has a flaw. I reply to post and it automatically checked "accept as solution". There is seemingly no way to undo this before I hit reply and make my post. Poor poor design on the forums as this subject is NOT resolved."
Where is it going wrong, cause this not good for the both of us. Besides that, I do not like to get the credits for an accepted solution when the problem is not solved.
Moderator edit: added label
12-08-2018 15:28
12-08-2018 15:28
I unmarked it as a solution
Wendy | CA | Moto G6 Android
12-08-2018 15:53 - edited 12-09-2018 04:57
Hi, thanks for that, but unfortunately my "accepted solution" for this answer I got from the poster also has gone: https://community.fitbit.com/t5/Versa/Versa-weather-synch-suddenly-not-working-after-8-mos/m-p/31061.... Proving it, see this: "Great job! yoyomum60 marked your answer to a question as an accepted solution!" I asked yoyomum60 to rate my post again as "accepted solution" but I do not know if this is possible. On one hand I can understand that the accepted solution from yoyomum60is deleted by accident, cause it was the only one I received untill now and , although, there was a mention that I got one from sethington, this was not the case. Errors are made easily.
