04-21-2018
03:20
18:40
EdsonFitbit
04-21-2018
03:20
18:40
EdsonFitbit
What do have to do to add elliptical to the excersise mode, and what mode does it have to be on for auto recognise?
Moderator edit: added label
@Terryjx1 Elliptical is an autorecognized exercise in all trackers that have SmartTrack, Versa included.
Laurie | Maryland
Best AnswerTo add Elliptical as one of your Exercise Shortcuts, go to the Fitbit app on your phone - click on the square in the top right corner and then click on Versa. Scroll down to click on Exercise Shortcuts. If 7 are listed, you need to delete one before you can add one. Click on Edit and remove one. Then click on +Exercise Shortcut to see the list of all the possible ones you can add - Elliptical should be in that list. If 7 aren’t listed, you can just click on +Exercise Shortcut.
I don’t know about Auto Recognize but I have posted the Versa Manual - search for it.
Laurie | Maryland
