12-25-2018 19:28 - last edited on 01-22-2020 17:33 by LiliyaFitbit
Can you adjust brightness on watch face (Versa)?
From clock face, swipe left to get to Settings, could take a few swipes. Tap Settings; at the top is 'Brightness' with settings auto, dim, normal, max. Auto works well for me, I think adjusting automatically to ambient light.
@Becbec7 wrote:Settings will not alwY me to change to auto or bright.... help. I need bright. Please and thx
Do you get to 'Settings'? If so, do you see the 'Brightness' option? If so, can you tap it and see the setting change?
Best AnswerYes I went to settings when I first set it up & i did choose bright. And it did work for the first half of the day. Then it went to dim. And now will not let me change it???? Should I do a factory reset?? And attempt to start again?
Best AnswerThere is no “max” in my settings. I can’t get anything but “normal”, which is too dim for me. I’m
