All of the sudden Versa 2 won’t turn on or charge
ANSWERED
I’ve read before threads and true cleaning the contacts and holding the button, but nothing… Is it dead or what? It’s about 4 years old now, but worked before. The last I’ve seen was Fitbit boot logo flashing multiple times and then it was gone.  
Charged is working (measured). The contacts look like this:
1 BEST ANSWER
Accepted Solutions
Hi @deejeekaa At 4 years old I would guess it has died if cleaning the contacts and restarting doesn't help. Sorry.
Community Council Member
Helen | Western Australia
5 REPLIES 5
Yeah, I guess. Reading the forums and based on my wife’s experience with multiple Charge trackers, looks like I was extremely lucky it lasted that long… Too bad. I was kinda happy with it. Time to move on then…
One of the metal contacts looks almost missing (middle left).  And another is 1/2 or 3/5 there (far right).  If the metal doesn't touch (device to charger) then it can't charge, I assume.
If you really wanted to, you could try to add some metal to the especially blank spot and see if it helps.  Like drop a bit of hot solder to make a puddle.  Or add a tiny bit of wire first to make a base for the solder to adhere to.  I'm no expert on trying to repair stuff like this though.
It’s the side contacts that deliver power it seems from measurements. I was playing with it and I think contact is there. I tried.
But thank you for suggestion! 😉
Hello everyone, and thank you for all the helpful input on this issue.
I'm sorry to hear your device stopped working unexpectedly. EternalStudent's suggestion is a good starting point if you want to troubleshoot further.
Like NellyG mentioned, it's unfortunate that you lost your device. We invite you to explore our latest models to find the perfect fit for your needs.
