05-01-2018 18:28
05-01-2018 18:28
I have the SE version. I have no problem getting the woven band off and on. I get one of the silicone sides on no problem. The other side? The pin keeps popping out. (Yes, it’s angled, pin pressed down, I’m aware of the ridges...) I’m about to give up. Bands shouldn’t be this difficult to switch out.
Anyone else experiencing issues it is it just me? I’m wondering if it’s my Versa. Especially since I’m only having difficulty on one side. (Always the same. )
11-12-2020 17:41
11-12-2020 17:41
Best Answer11-12-2020 18:58
11-12-2020 18:58
Yes, she does. I can totally understand you ending up going to a jeweller...I hope they did not charge you too much
Best Answer12-19-2022 04:31
12-19-2022 04:31
Thanks. Worked.
Best Answer04-05-2023 05:09
04-05-2023 05:09
Agreed that it should NOT be this difficult to change bands. I have a new Iconic 3. This is my 5th Fitbit I've had. I have NEVER had this much trouble switching bands. This design is cumbersome. I now have to set aside an extra 5-10 minutes getting ready in the morning if I want to change out bands. I might go back to my Charge 5, which I can change out in 30 seconds. This design is awful.
