07-23-2019 11:49
07-23-2019 11:49
I have a versa, paired to iPhone 7 Plus. The versa shows all the dots but the app won’t Versa screen
App screen.
The pictures are just after syncing. This isn’t very frustrating.
07-23-2019 12:07
07-23-2019 12:07
Same here with iPhone X..very frustrating
Best Answer07-23-2019 17:32
07-23-2019 17:32
This is a known issue that is affect some users and Fitbit is looking into this.
07-24-2019 01:29
07-24-2019 01:29
Same again today 😡
Best Answer07-24-2019 04:40
07-24-2019 04:40
Best Answer07-24-2019 05:25
07-24-2019 05:25
It is so much easier when a problem is consistent for the users affected and even easier to fix when a problem affects everyone.
Neither of which is the case here.
Hopefully the cause can be found soon.
07-24-2019 17:42
07-24-2019 17:42
Best Answer07-24-2019 20:29
07-24-2019 20:29
Mine has been doing that since Sunday. I have deleted and reinstalled the app; disconnect and reconnect to Bluetooth and the internet.
Best Answer07-25-2019 00:00
07-25-2019 00:00
Active hours don't sync from the tracker to your account. When you ask for the day, the server looks at the hourly step totals and calculates this.
07-25-2019 03:59
07-25-2019 03:59
07-25-2019 09:04
07-25-2019 09:04
Best Answer07-25-2019 09:22
07-25-2019 09:22
Best Answer07-25-2019 11:18
07-25-2019 11:18
Yes it should show the same, and for many of us it does.
This means there is a problem someplace that has to be identified and fixed. Fitbit is aware of this.
Best Answer07-25-2019 11:21
07-25-2019 11:21
Best Answer07-25-2019 14:14
07-25-2019 14:14
