05-05-2019 04:48
05-05-2019 04:48
I have enabled autotrack for bike feature on my Versa. But I found that it starts tracking even when I am driving my motorbike or car at a slow speed as a cycling activity How do I fix it.
05-05-2019 18:38
05-05-2019 18:38
The easiest way is to delete the activity, apparently when driving at a slow speed, your arm motions are the same as when riding a bike.
Sorry
05-06-2019 03:52
05-06-2019 03:52
Hmmm... I dont like it. Thats not a good way to auto-track, and certainly not a good way to get rid off it.
Sorry. I didnt like the idea.
Regards
05-06-2019 05:26
05-06-2019 05:26
@SunsetRunner I can understand why you are frustrated by this weird tracking. I got an outdoor bike once while driving, but only once. It sounds like this is a common occurrence for you.
If the bad auto-tracking is the bigger problem, then you should think about turning off the bike auto-tracking. Then turn it on when you ride a bike. You might not like that idea, either. Your choice might be between two ideas that you don't like.
Laurie | Maryland
