07-15-2022
08:50
17:47
07-15-2022
08:50
17:47
Folks: Not sure if there is an EASY fix other than buying another brand, but my bands I've purchased and the one provided simply disconnect! I've been driving, walking, and the watch falls to the floor.
Is this just a design flaw? Has anyone had this happen? I've recommended Versa 3's to a few people but now maybe not.
07-18-2022 08:30
07-18-2022 08:30
Hi - quick note. I connected via Twitter using @FitbitSupport and even created a short video for them in which the band disconnected twice in less than 90 seconds just connecting the band to the watch and then moving it, once I put it on, on my wrist. They're now sending me a new watch.
Note that the first solution was to send replacement bands but did not work.
07-16-2022 05:58
07-16-2022 05:58
I am having the exact same issue, it only seems to be one connector that keeps coming loose and I have tried several straps. I’ve only had my Versa 3 a number of weeks and it has fallen off many times as the strap just disconnects
07-16-2022 11:15
07-16-2022 11:15
I am having the same issue and the last time it disconnected it hit the pavement and there is a crack in the screen now!
07-16-2022 11:48
07-16-2022 11:48
07-18-2022 08:30
07-18-2022 08:30
07-18-2022 08:30
07-18-2022 08:30
11-30-2022 13:18
11-30-2022 13:18
Have tried 2 different bands. Same band multiple disconnect issue.
12-03-2022 16:31
12-03-2022 16:31
I had the same issue. Switch your the bands to their opposite sides
