04-03-2020 12:22
04-03-2020 12:22
My Versa's battery recently began dying after a little over a day. Previously the battery would last for several days. When it dies completely, I have to manually re-sync it. What is causing this and can it be fixed?
04-03-2020 14:44
04-03-2020 14:44
Yes, I have the same issue recently and I'm wondering if it's to do with the recent update I did yesterday
04-03-2020 15:22
04-03-2020 15:22
Yes, that's certainly a possibility, I hadn't thought of that! But I do update all the time. This problem came on very suddenly; it was fine before.
04-03-2020 16:19
04-03-2020 16:19
I’ve just shut down my Fitbit and turned it back on again. It’s now charged at 100% so I’ll see what % it’s at when I wake up tomorrow!
Best Answer04-03-2020 16:46
04-03-2020 16:46
Best Answer04-03-2020 18:04
04-03-2020 18:04
I am having the same problem as well. I have tried resetting fitbit, but it is still not working. it would be helpful if anyone from the fitbit provides any information on this.
04-03-2020 18:37
04-03-2020 18:37
Best Answer04-03-2020 21:18
04-03-2020 21:18
The battery has completely drained already! This is so annoying because I bought this in november!
04-04-2020 06:32
04-04-2020 06:32
Same issue. Started in last couple of weeks.
04-04-2020 09:44
04-04-2020 09:44
Same. Battery drains in hour or 2. Heart rate monitor not working. No sleep tracking. Feminine tracking has been glitching. Steps have been freezing. Basically my Versa is now an expensive useless bracelet. I’ve followed all online suggestions and it’s just broken I guess. This happened about a week ago and my husband’s Versa just started the same problem a couple days ago. Thinking of switching to an Apple Watch since we are both avid runners and running is helping us so much during this pandemic. Has Fitbit stopped service on the Versa?
04-04-2020 09:57
04-04-2020 09:57
Interesting. I can't get through to Fitbit. Has anyone been able to actually talk with them about a solution? If they can't fix this, then I agree that Apple would be a better solution.
04-04-2020 14:21
04-04-2020 14:21
I’ve had my Versa 2 since Xmas. Within the last month, the battery lasts 48 hours. I completed the update and the problem persists. If anyone finds a solution let me know. Thanks so much!
04-04-2020 17:31 - edited 04-04-2020 19:05
I’ve been having this issue for the last 3 days, my battery drained from 70% late yesterday afternoon to 9% when I woke this morning.
Last week my Versa was restarting every hour, sometimes twice an hour and the swipe wasn’t working at all. That seems like it’s fixed now but the battery is draining excessively fast without me using it much (just wearing - no tracking fitness, no checking it regularly).
update: swipe has gone back to not working at all. Frustrated.
04-08-2020 11:33
04-08-2020 11:33
I have had the same issue and it frustrating for sure. I love my fit bit and do not want to move to apple... I prefer Fitbit...someone please help us!!!
04-08-2020 16:20
04-08-2020 16:20
I did a soft restart and the battery seems ok now but it’s gone back to restarting multiple times through the day & night, and the swipe isn’t working at all. Ugh!! Fitbit please fix your software.
04-16-2020 16:00
04-16-2020 16:00
And the only reason I haven’t dumped the Versa and switch to Apple Watch is because of the sleep tracking which I really need. I hope they get this battery drain issue fixed soon!
Best Answer04-16-2020 17:36
04-16-2020 17:36
I haven't done an update on mine... can it do it automatically?
Best Answer04-16-2020 17:53
04-16-2020 17:53
04-16-2020 17:58
04-16-2020 17:58
You can always check for updates manually. Press your image in the upper left corner of the dashboard. Then tap on help, then tap on “check for versa updates.“
04-16-2020 18:00
04-16-2020 18:00
No, it has not been fixed. The latest is I have to reboot manually several times a day now. And sometimes it shows zero battery percentage but then when I put it in the charger in five minutes it will show 100% battery. Then if I wear it for a few minutes, it will go down to 40 or 50% battery. It’s a mess!
