09-07-2019 14:38
09-07-2019 14:38
I've had my Versa for about 6-7 months now and while it used to last for four or five days at least now it seems as if I have to charge it every day and half or so.
What gives Fitbit??? not happy it really shouldn't drain this quickly
Don't use it for music or even to track exercises as it won't stay on while cycling . I had posted this issue once before and there is no resolution to it stopping and starting itself due to wrists pausing and starting it constantly when i flex hand to change positions on the bike.
09-07-2019 17:22
09-07-2019 17:22
Hi @KevinTKroencke Have a look at THIS Help Article on Battery Life and see if anything there helps. If it doesnt then I suggest you contact Supoort. Contact Support
As far as the bike problem, Id suggest you try wearing the watch a bit further up your arm, not right on your wrist, so flexing doesnt press any buttons. I have never had that problem with mine but I do wear it above my wrist bone.
Helen | Western Australia
09-08-2019 06:59
09-08-2019 06:59
