Battery Life
hey there, my battery seems to last only 2 days- is this normal?
3 REPLIES 3
Maybe if you have snore detection turned on permanently.
Some settings do affect the battery - e.g.  clock face always on; not sure if brightness makes a difference, and possibly if you are often checking different things on it? Good luck.
Thank you- I;ll try that
