05-10-2019
18:01
03:44
DavideFitbit
05-10-2019
18:01
03:44
DavideFitbit
I purchased my Versa Lite o. Monday 5/6/2019 I have already had to charge it twice. I thought the battery was supposed to last 4+ days? I am wondering if I have a defective product!
This is my first Fitbit and I was super excited to get it.
Anyone have a solution?
Thanks in advance
Best Answer05-10-2019 20:04
05-10-2019 20:04
Hi @AlisaC45 if you got it on the 5th, today is the 11th so you have charged it twice in 6 days - is that correct? At what percentage was the battery when you charged? It is advertised as 4+ days, but that depends on what you have turned on and how often the screen turns on. Big battery users are notifications (especially if you get a lot) and all day sync, plus looking at it a lot (which you tend to do with a new device). I have a Versa (not lite) and I generally charge after 3 days (i have notifications on but not all day sync), so on those figures Yours doesnt sound as if it is doing badly. Come back with more information for a clearer picture about what is going on.
Oh additionally when I first got my Inspire the battery didnt last the advertised 5+ days or anything near (it died after 2 and a bit days) but over the next week or 10 days or so of regular charging before it ran right down, the performance improved to over 3 days, so you battery may improve over the next week or so too
Helen | Western Australia
Best Answer05-11-2019 05:48
05-11-2019 05:48
Best Answer05-11-2019 06:10 - edited 05-11-2019 06:30
@AlisaC45 One piece of information that will help decide if you have a serious battery is issue is, how much did the battery percent drop between charges? If you don't remember exactly from first use, then start to keep some personal notes to follow and report back.
@NellyG has some excellent advice for optimizing battery life. Here is a link to Fitbit's Help Article with more tips.
Keep us informed. Sometimes users get a bad battery.
Laurie | Maryland
05-11-2019 06:19
05-11-2019 06:19
Thanks for coming back with more information @AlisaC45 Have a look at the article @LZeeW linked, but if nothing improves it, come back here again, as it could be faulty.
Best Answer05-11-2019 06:31
05-11-2019 06:31
From Thursday evening (full charge) to Fri evening it went down 90%. I noticed it only takes a short time to charge the battery, I am assuming this is normal (10min) ?
NellyG pointed out some good tips, I have turned notifications off and reduced the screens brightness, also, I just un-synced with my phone, I want to see how the battery does today.
Thank you so much for your help
Best Answer05-11-2019 06:56 - edited 05-11-2019 08:24
@AlisaC45 Just a clarification. Are you saying that in 24 hours your charge dropped by 90% to 10% remaining? If that is what you are saying, then that sounds like a bad battery.
On a typical day my Versa will drop by 12% to 88% battery. I need to look at my watch frequently (to data and time documents), don't get a lot of notifications, have my screen brightness on automatic, and my screen display at 10 seconds. I don't have all-day sync on. I don't play music from my Versa. Using the exercise app does use a bit more.
Laurie | Maryland
Best Answer05-11-2019 07:43 - edited 05-11-2019 07:45
@AlisaC45 Something sounds wrong. With only 10% charge left (which I think is what you are saying) it should take a couple of hours to charge. And dropping 90% in one day is way too much. I will flag a moderator to assist you further, though if you bought it from a store other than the Fitbit online store then you will need to return it to where you bought it.
Best Answer05-11-2019 08:57
05-11-2019 08:57
Best Answer05-12-2019 07:59
05-12-2019 07:59
Welcome to the Forums @AlisaC45. Hello @LZeeW and @NellyG.
Thanks for being around to help and for bringing this thread up @NellyG and @LZeeW! @AlisaC45 Thank you for trying the steps that were suggested.
@AlisaC45 Our support team will be getting in touch with you about your battery situation via email. Be sure to keep an eye on your email's inbox, spam and trash folders. They will be more than happy to help you and I'm sure that a solution will be found for you.
Let me know if there are any other questions or if we can help you with anything.
