08-08-2020
12:20
15:13
08-08-2020
12:20
15:13
I get a email stating my battery is low.
I put it on charge.
it fully charges but the message on my device st states that the battery needs charging. Despite trying to delete this message. It doesn’t go. Why? What should I do please?
08-10-2020 15:17 - edited 11-28-2023 01:37
Hi there @Acheebachee, welcome to the Community Forums. Thanks for the details shared in your post about the battery low notification that won't go away after fully charging your Versa 2.
While reading your post I was wondering if the message is on your Versa 2 or the Fitbit app? Note that the battery percentage on your Fitbit app updates every time you sync. So if you haven't synced yet, your app will remain the battery percentage of the last synced.
Once you charge your watch make sure to sync and you'll see that the percentage on your Versa 2 will match with the one on your Fitbit app.
Hope this information helps, I'll be around if there's anything else I may do for you. 🙂
Best Answer08-10-2020 15:39
08-10-2020 15:39
Best Answer08-10-2020 16:46 - edited 10-03-2023 10:04
Hi there @Acheebachee, thanks for getting back and clarifying where the message was on. I'm glad to hear that the restart you performed solved the issue.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
