Best clock faces Versa
ANSWERED
I want to know what the best clock faces are for the Fitbit Versa.
Callum Slatyer
1 BEST ANSWER
Accepted Solutions
Alright Thanks @SunsetRunner ill give it a go.
Callum Slatyer
10 REPLIES 10
Hi, if you really want the best Clock Faces for your Versa, go to Clocks - All Clocks - press the search icon on top of the screen on the right side. A new, empty, page will show with a search bar and the search icon on top of the screen on the left side. Press that and type in "azara" and you will get all the Faces he has developed for the Versa. If I may make a suggestion: choose the "Digital One". Although this is a payed Face, it's worth every penny of it after a 30 hrs trial period. This Face is not only highly customizable, but exists of two screens: the Home Dsiplay and, after a slight tap on this screen, it shows you the seperate Stats Screen, showing: Steps - Floors - Calories burned - Distance - Active Minutes and HR. Besides that, ir's also very battery friendly. I use this Face myself for a while now and my battery lastst 5+ days with it. Try it out and you will get addicted to it, just like me.
Thank you very much @SunsetRunner I will try the watch face you have suggested but you said it cost money and i dont want to spend any money on watchfaces.
Callum Slatyer
Hi, it costs only $1.1 after a 30 hrs trial period, so I would say "give it a try, you have 30 hrs for that to decide". I personally helped the developer of this Face to get the Stats Screen with a very clean face and thus very clear readable. Hope you will try it and spent a mere $1.1 for the best Clock Face that's at this moment available for the Versa and I can know, cause I used and tried a lot of clock Faces. Good luck!!
Callum Slatyer
Hi, I'm convinced that you will not be disappointed cause Marc Azara makes the best Clock Faces for the Versa of every Third Party Clock Face developer. And, they are all comaptible with the new Firmware Version, so you do not get problems with it sooner or later. Enjoy it!!
BTW, if you need any help in customizing this Clock Face to your own liking, do not hesitate to contact me either in the Community or by PM!!
Hi there, I’m looking for this face, but I can’t seem to find it!
I couldn't find any Azara clock faces. Was he kicked out?
Unable to find Marc Azara when searching. Please advise
I use Awesome Clock by ZenApps. It’s my favorite because it’s a clean design and gives you a lot of info in a very organized and easy to read design. Check it out.
Try free SimpleClock, it has a log and a prediction of when charging is complete, along with an always on display while charging, showing current time.
Optional reminders to drink and move, with large digits to be easy to read and navigate.
https://gallery.fitbit.com/details/b3d7fabf-4cb1-4e58-9253-19697ce22800
