What is up with the Bitmoji clock face? It will not load and when you get the pop up window that tells you it won't load and asks you if you want to continue or try later and you click on later it still continues anyways.
Best AnswerHi @SunsetRunner , in order to make use of this CF, you will need a Snapchat and Bitmoji account and be logges in on these two accounts before you can use it properly. If I may make a suggestion: do not use this CF, cause it related to a lot of problems, as you already noticed. Choose another CF developed by Fitbit or a free Third Party Clock Face, like f.i. Minimal Style. Highly customizable, indeed minimal but with all possibilities you would want and only 8.6 kB in size, so very battery friendly. My Versa 2 lasts at least 7 days on one charge with this CF. Regards kuzibri
Thank you. Yes I have a Snapchat and Bitmoji account and yes I am and was
logged into them. I just wanted to see the clock face with my bitmoji on
it. I have noticed there's been a lot of problems associated with that
clock face and I'm not going to use it. I'm actually reluctant to use any
third-party app for fear that it's going to cause issues that are very
difficult to figure out.
Hi @SunsetRunner , many thanks and the CF I mentioned to you in my first reply, you can use that safely cause I use it already for more than one year without any problems at all, first on my Versa 1 and now on my Versa 2. If you should decide to use the Minimal Style CF and you have any problems with it, which I do not expect, you can always contact me by PM. Regards kuzibri
