09-29-2019 15:41
09-29-2019 15:41
I have, as others, used the bitmoji clock face successfully... but after I changed it to another clock face, and then tried to use it again it is stuck on "connected preparing to teleport...."
I factory reset the Versa, un and reinstalled the fit bit and snapchat app and nothing is working
10-02-2019 22:11
10-02-2019 22:11
It takes forever for it to connect. Just set it aside at night before you go to sleep and hopefully it will connect by the time you wake up
I have it on a different watch that I dont wear all the time. And I want to keep it so I wont be changing the clock face as it is a pain
Wendy | CA | Moto G6 Android
10-02-2019 22:11
10-02-2019 22:11
10-03-2019 18:23
10-03-2019 18:23
Yes it finally works !!! It did take overnight ....thanks!
