01-12-2020 16:10
01-12-2020 16:10
Bitmoji clock face is not functioning properly all of a sudden. I restarted the Versa Lite but that didn't help.
01-12-2020 17:10
01-12-2020 17:10
Hi @SunsetRunner , I would strongly advice you to not use this Clock Face cause it leads to a lot of troubles. Type the name of this Clock Face in the search bar of the Versa's Homepage and you will find a lot of topics regarding this Clock Face. Besides that, it's eating up your battery. regards kuzibri
01-12-2020 17:17
01-12-2020 17:17
@SunsetRunner thank you for the suggestion. I have had problems with it periodicallly, but I've managed to solve them but I have had my suspicions of there being bugs with this clock face. I only use Fitbit clock faces and the Bitmoji falls in that category but I realize it's not solely Fitbit controlled. I actually removed the clock face and then reinstalled it and reconnected the two accounts and it's working now.
01-14-2020 11:06
01-14-2020 11:06
@SunsetRunner Would you happen to know which one of the Fitbit CF uses the least amount of battery? Is it as simple as picking the one with the smallest file size?
01-14-2020 11:22
01-14-2020 11:22
Hi @SunsetRunner , I know you asked for a Fitbit CF, but I'm using a Third Party Clock Face ever since I bought my Versa 1 more than one year ago and now on my Versa 2 for three months and never had a problem with it. This CF is called Minimal Style and it's size is a only 8.7 kB but with an awful lot of customizable settings, which is almost hard to belief with this size. I also know the developer very well. With this CF installed, the battery of my Versa 2 last 7 days on one charge. I have made the max customization to this CF, so what is on my display now is (From top to bottom): Date - Digital Time - Bottom left corner:HR - Bottom Midle:Steps and by pressing them you can cycle through all the other relevant stats - Bottom Right:Battery in %. All customizable in every color you want/wish. Give it a try and you will love it. I personally never have the urge to change to another one. Regards kuzibri
01-14-2020 11:31 - edited 01-14-2020 11:38
@SunsetRunner I think I found the one you're talking about. It certainly does have a lot of colors and is very customizable. I especially like having the battery indicator and the heart rate. Thank you, thank you, thank you!
01-14-2020 11:37
01-14-2020 11:37
Hi @SunsetRunner , type in the search bar: "Minimal Style" (this is the exact name) and you will see it on top of the list on the left side. Developer is Lee Doel. Regards kuzibri
01-14-2020 11:41
01-14-2020 11:41
Hi @SunsetRunner , if you cannot find it CF, this is then caused by the fact that Lee is updating this CF, on my request, for the Versa Lite, which has a different display size. He just updated his CF so maybe he already updated it. regards kuzibri
01-14-2020 11:46
01-14-2020 11:46
@SunsetRunnerI found it and I am using it right now. Thank you, thank you, thank you. I like that the heart rate is there and I don't have to keep tapping the screen to have it visible all the time and I really like having the battery life indicator. This CF is truly awesome!
01-14-2020 12:31
01-14-2020 12:31
@SunsetRunner , enjoy it, just I already do for 1.5 years. Be glad I made a personal request to the developer to adjust this CF for the Versa Lite also, because it was'n't available for the Lite. I have three friends with a Lite who were very jeaulous cause I had this CF and they could not. Hence my request to the developer. regards kuzibri
