11-20-2023 16:36
11-20-2023 16:36
Hello, I added the bitmoji watch face but it is stuck, has the constantly spinning ball & I can't delete it, It is preventing me from adding other faces
11-29-2023 20:52
11-29-2023 20:52
@Di-Miles - it is weird the face continues to load which will block others.
Try removing the watch from the app, remove it's Bluetooth entries from the phone, logout of the app, swipe off the active window clear the cache, force stop it and restart the phone.
Factory reset the watch then login and add it new to the account.
Best Answer11-20-2023 19:56
11-21-2023 04:31
11-21-2023 04:31
11-21-2023 04:45
11-21-2023 04:45
Thanks, @Di-Miles - it seems the factory reset hasn't worked and may not even be necessary.
First try swipe the watch face to the left and tap the clocks app to choose another clock and sync. This may break the cycle.
If that doesn't break the cycle remove both the Bluetooth entries for the watch from the phone's Bluetooth.
Logout of the Fitbit App and swipe off the active window and in Android clear the storage cache and force stop it and then restart the phone
Make sure there are no other devices running the Fitbit App switched on and no other Fitbit devices are switched on.
Restart the watch by holding the button for a full 10 seconds till it vibrates and the logo appears and wait for it to start.
Login and do set-up the watch and replace.
If it still fails remove the watch from the account and repeat the above process, rather tedious as it can be quite difficult to stop when it's not working right.
11-29-2023 17:08
11-29-2023 17:08
Thanks but I've done that - more than 5 times, it won't save any new faces, that Bitmoji face just keeps on spinning. I've done a factory re-set 3 times, followed all the instructions from the Help line & nothing will get rid of that face, it's driving me nuts!! I've spent hours messing with it!!
Best Answer11-29-2023 17:30
11-29-2023 17:30
Hello, thanks for that info. I've left it alone for a week or so as I just don't have the time to mess with it. Just done another factory re-set, tried downloading more clock faces but it will only save the last one & the other 4 are stuck forever. The Bitmoji face won't go away, just keeps spinning & using up battery life. I have transferred to my Google Acc
Best Answer11-29-2023 20:52
11-29-2023 20:52
Best Answer11-30-2023 04:54
11-30-2023 04:54
Best Answer11-30-2023 05:13
11-30-2023 05:13
@Di-Miles- thanks for trying, and your patience, odd indeed.
There is perhaps another option. If the watch is in working order, swipe the watch face to the left and tap the Clocks app and change to another clock face. Then sync the watch with the app.
This should make the new clock face the default one and you may then be able to remove Bitmoji clock with "Remove clock face". in the Gallery tile.
Note: restarting the watch by holding the button for 10 seconds retains the existing clock faces - only a full factory reset erases them. But the above should work.
