Bluetooth connection
Does anyone know how to prioritize Bluetooth connections for Windows 10?
5 REPLIES 5
Hi, what do you mean exactly, could you explain a bit further?
I have difficulty syncing my Versa with my computer but usually have no
problem syncing it with my wife's computer. I noticed that I have more
Bluetooth connections that she does. I am not sure what most of them are
but have read that other Bluetooth connections may be interfering with
the Versa syncing. Rather than just removing them and possibly causing a
problem, I thought if I could prioritize them by moving Versa further up
the chain that may solve the problem (if that is the problem).
Thanks for your elaborate reply. AFAIK, it's not possible in Windows 10 to make a certain BT device more important than the others. If your wife's computer is out of your computer's BT range than that should not be a problem. IMO you can do two things:
1. Before syncing your Versa with your computer, go to the settings of Win 10 and enable BT (which is normally not necessary once you have paired it with your computer). If that does not solve the problem:
2. Remoce your Versa from the BT list, set BT to on and press add device and pair your Versa again with your computer.
Hope this helps.
Thanks for your suggestion. Removing the Versa from Bluetooth works more
often than anything else I've tried but the longest time it has worked
for me is three days, and then nothing works for a while. Incidentally,
when I remove the Versa from Bluetooth and then try to pair it with
Bluetooth, it will find other devices that are farther away from the
computer but not find the Versa, which is very close. However, using the
Versa app and the Sync command apparently forces the pairing and then
Versa is Synced.
Hi, just a suggestion: next time you need to pair your Versa to your PC, switch off all other BT devices, so only the BT on your Versa is enabled. Your PC will find the Versa inthis case much faster.
