04-04-2019
18:12
11:06
DavideFitbit
04-04-2019
18:12
11:06
DavideFitbit
Everything is logging incorrectly!
04-04-2019 18:16
04-04-2019 18:16
Hi, could you be more specific than only mentioning that everything is wrong? By your message I'm not able to try and help you.
04-05-2019 06:54
04-05-2019 06:54
Best Answer04-05-2019 07:23
04-05-2019 07:23
Hi, I do not know why your Versa is acting this way, but I can make a suggestion to solve this. Restart your Versa 4-6 times in a row by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons. Usually this procedure solves a lot of these problems. Good luck!!
