01-27-2021 03:51
01-27-2021 03:51
Is Bluetooth LE a new equirement via the newest update? I've had my V2 for over a year and it's not syncing anymore.
My phone is no listed as, "approved."
It IS bluetooth 4.2.
Done:
On/off for both
Unpair/repair
Uninstall/reinstall
Factory Reset
Also, I installed Fitbit app on my windows 10 laptop and it is syncing there. This is asinine.
01-27-2021 03:59
01-27-2021 03:59
Are you referring to the update to the android app (version 3.37)? If so, there's a known bug with syncing for some of us. Keep an eye on the following thread where Fitbit are posting updates:
Best Answer01-27-2021 04:46
01-27-2021 04:46
Not sure. I think me saying it won't sync is misleading. It's not connecting via bluetooth.
My bluetooth settings say, "Unable to pair. Check settings for this device and try again."
I had a firmware update, and an app update back to back. Not sure which was first.
